Inlägg av Lars Söderman på 2015-02-24 12:39
That would be a transponder of typ ID44 = PCF7935, but you can also use a T5 transponder emulating the 7935.
I dont know where it’s located in the key, I’ve never opened one.
May I ask why you wan’t to open the key? Wouldn’t it be easier just to make a copy of the key, and a copy of the transponder?
I can assist you with copying the transponder if that is of any help, or you can try Låspunkten in Sundbyberg who probably can make both a key and copy the transponder.
Thank you with your fast reply. The reason I ask this because my key body have a big crack and the blade soon will came out from the body.
I just want to put the blade and transponder in the new body shell, because I don’t have the code card.
I asked alfa workshop they charge 2k kr for a copy. such money I don’t have. Beside its not like I lost the key. So I don’t think pay 2000kr is a smart way to do it.
Thank you again.
may I ask how much cost if you could help me with a transponder. (I don’t have the code, but I have both keys)
