› Forum › Allmänt › Tvätta mattlackerad alfa, launch edition › Svar till: Tvätta mattlackerad alfa, launch edition
har du fått bilen inu ? eller du väntar på den fortfarande.
oavsett vilket så ska du ha fått me instruktioner av säljaren på vad du ska tänka på när du tvättar en sådan bil med den typen av
lacken, har du inte fått din bil inu om du beställt en ny så ska du få detta med. bara på dom och fråga. så här står det i ett servicenew från fiat jag hittade i våra program på jobb. detta gäller breran med den färgen.
| NEW COLOUR TITANIO OPACO (MATT TITANIUM – OPAQUE METALLIC GREY) Precautions and warnings – Network Information |
Cancels and replaces SN 70.04.09 of
From the end of September 2009 a new
metallic paint with opaque finishing, called Titanio Opaco (Matt Titanium),
shall be available on Alfa Romeo Brera models.
Please note that, due to the matt
features of this new “Titanio Opaco” (Matt Titanium) paint, special care should
be paid by the customer; to preserve the painting aesthetical characteristics,
the Customer should comply with the instructions of the Owner Handbook and in
particular:
-paint should never be scratched with cloth as glossy local areas
could arise;-possible scratches or abrasions should not be removed by polishing
the area with special wax and car polish;-do not park the car under trees,
especially conifers: the resinous substance and bird droppings must be washed
off immediately;-the car must be exclusively hand washed using neutral pH
detergents and cleaned/dried with wet chamois leather; do not use polish nor wax
it;
do
The new Titanio (Titanium) colour is
standard applied by a double-layer painting cycle (base coat + clear opaque
coat).
A
silver plate is located inside the tailgate for the identification of the
paintwork, with the colour identification code VR702B.In
case of doubt, before any painting operation, if necessary, refer to the Service
News 70.11.05 and the Data Sheet from the supplier of the paint product to
define the preparation and application techniques.Please note that, during repair
operations, the whole part should be painted (e.g. wing or roof) to prevent any
shading, that would result in surface differences from the touch-up and the
original part.
