Färkod Brera /spider
Forum Teknik Färkod Brera /spider
  • #24156
    Anders Eriksson
      Alfa har tillverkat en begränsad serie av Brera och Spider, kallad “Italia Independent”. Just en sådan Brera stod på Clubbens årsmöte 2009.
      En titan-grå lack, sidenmatt. Jag tycker att denna färg är mycket snygg, och söker därför rätt färgkod..  Finns det någon på forumet som besitter möjlighet att få fram den??    Nej, tyvärr har jag inget regnummer eller chassinummer att söka på.
      Tack så länge //Anders
      Nu: 4C
      #24157
        förmodar det är denna färgen du är ute efter. lite info om färgen och hur den ska skötas
        From the end of September 2009 a new metallic paint with opaque finishing, called Titanio Opaco (Matt Titanium), shall be available on Alfa Romeo Brera models.Precautions and warningPlease note that, due to the matt features of this new “Titanio Opaco” (Matt Titanium) paint, special care should be paid by the customer; to preserve the painting aesthetical characteristics, the Customer should comply with the instructions of the Owner Handbook and in particular:-paint should never be scratched with cloth as glossy local areas could arise;-possible scratches or abrasions should not be removed by polishing the area with special wax and car polish;-do not park the car under trees, especially conifers: the resinous substance and bird droppings must be washed off immediately;-the car must be exclusively hand washed using neutral pH detergents and cleaned/dried with wet chamois leather; do not use polish nor wax it;do not use brushes and high-pressure washing systems: automatic washing systems (if too powerful) could generate glossy areas that cannot be removed anymore.The new Titanio (Titanium) colour is standard applied by a double-layer painting cycle (base coat + clear opaque coat).A silver plate is located inside the tailgate for the identification of the paintwork, with the colour identification code VR702B.
        In case of doubt, before any painting operation, if necessary, refer to the Service News 70.11.05 and the Data Sheet from the supplier of the paint product to define the preparation and application techniques.Please note that, during repair operations, the whole part should be painted (e.g. wing or roof) to prevent any shading, that would result in surface differences from the touch-up and the original part.
        #24158
          Finns en till salu i italien nu på Mobile.de eller autoscout-24 !
          #24159
          Magnus Berg
            Har också hört att det är väldigt besvärligt att underhålla denna färg, precis som Rickards inlägg bekräftar. Tror inte jag skulle välja denna lack. Risk att ens hår snabbt antar samma färg som bilen.
            Blev förvånad när jag såg att nya Giulietta QV och Mito QV har en färg som ser likadan ut. Får hoppas den är av annan kvalité och lättare att underhålla.
            #24160
            Anders Eriksson
              SuperTACK Rickard som hittade färgkoden!! Japp, det är den jag söker!
              Dock, efter att ha läst hela ditt inlägg med varningar och skötselinstruktioner… nja, blir nog att välja en annan färg. Den där titangråa verkar inte vara avsedd för fordon som ska brukas.
              Återigen, detta är ju ett fantastiskt forum, verkar finnas svar på allt
              Nu: 4C
              #24161
                ja det är en läcker färg men som du säger. känns mer som en färg till bilar som inte körs mer än till utställningar..
                hur kul är det att tvåtta med fel bilschampo o så är den finishen borta som man vill bibehålla..
                såg den på årsmötet i sthlm men fasiken va känslig den var bara man tog på den så blev det avtryck efter fingrarna..
                #24162
                  Det är samma med alla tillverkares matta lacker, ska nog undvikas om det är en bil som ska brukas på riktigt. Det är ju ganska lätt att föreställa sig hur trist en sån lack ser ut efter några år av användande. Men på en lekbil som används sparsamt och som man kan ha full kontroll på hur den förvaras så visst.
                  Finns dock en del specialprodukter från t.ex Swissvax för matta lacker. http://www.swissvax.us/usa/matt-paint.html
